Mattonius Posted May 28, 2016 Report Share Posted May 28, 2016 Hello, recently was released new web broswer ( Vivaldi ) from developers of old Opera. It seems to be soon very popular around advanced users.Please improve your cleaner to be able to clean this broswer as well.THANK you, Matt Michaeltrili, LuannaPub, Lesterjet and 3 others 6 Link to comment Share on other sites More sharing options...
xilolee Posted May 28, 2016 Report Share Posted May 28, 2016 Hi Mattonius. In the meanwhile wisecleaner team adds it, you can modify Vivaldi shortcut: right-click Vivaldi shortcut, click properties, click the shortcut tab, in the target entry append -incognito, click ok. Link to comment Share on other sites More sharing options...
Mattonius Posted May 28, 2016 Author Report Share Posted May 28, 2016 I do not think, that annoymous tabs will help me Never mind, I will just need to wait ) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 30, 2016 Report Share Posted May 30, 2016 Thanks xiolee. and thanks Mattonius, we will add it shortly. Link to comment Share on other sites More sharing options...
云淡风轻 Posted May 30, 2016 Report Share Posted May 30, 2016 @Mattonius, As i know, Vivaldi is using chromium kernel, so cleaning Vivaldi should be similar as Google Chrome. I created a UserCustom.ini for wise disk cleaner, it can clean Vivaldi and Yandex browser. I just begin to use Vivaldi, I'm not sure this file can work perfectly. When you download it, please change it to UserCustom.ini, then paste it to WDC folder. UserCustom.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 1, 2016 Report Share Posted June 1, 2016 Thanks. I will open a new topic for your custom file, and we will test it. If it works well, we will add it to WDC. Link to comment Share on other sites More sharing options...
Mattonius Posted November 1, 2016 Author Report Share Posted November 1, 2016 Any progress by adding it to WDC? Link to comment Share on other sites More sharing options...
xilolee Posted November 1, 2016 Report Share Posted November 1, 2016 Did you try the usercustom.ini provided by 云淡风轻? Did/does it work? I do not think, that annoymous tabs will help me It works; when I'm in incognito mode, the history won't appear at all: Steps: Create a shortcut to Vivaldi.exe and put it on the desktop (or where you prefer) Right-click the shortcut, click properties, go to the shortcut tab, append --incognito in the target entry, click ok Example: I have "installed" (the portable version) in D:\Browsers In the target entry I had got D:\Browsers\Vivaldi\Application\vivaldi.exe I added --incognito and it became D:\Browsers\Vivaldi\Application\vivaldi.exe --incognito Link to comment Share on other sites More sharing options...
Mattonius Posted November 3, 2016 Author Report Share Posted November 3, 2016 of course I know how to use incognito tab, problem is I want to clear the data in some intervals, not all the time. with annonymous tab I cant look to history and reopen once closed tabs and so on. The usercustom.ini or txt works quite fine but not as good as I would expect, I can't choose there what I want to delete or not, it will delete all my files including passwords or nothing... You know, I love WDC because I can delete history, files in 3 diferent broswers at the sime time by one click as well as garbage all around the computer. Link to comment Share on other sites More sharing options...
xilolee Posted November 3, 2016 Report Share Posted November 3, 2016 I have now made a try: I have downloaded and installed Vivaldi (latest x64 version), in its default path (c:\program files\Vivaldi). WCare365 without usercustom.ini finds: cache localstorage autocomplete form history saved passwords session With usercustom.ini, it finds also cookies (maybe the WiseCleaner team forgot to add them in the program). We can tick or untick checkboxes and WCare365 should remember our choices (although I know there's a problem: it sometimes forgets the settings). Hence, exactly, what do you think it's missing? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 16, 2016 Report Share Posted November 16, 2016 Thanks for your feedback. We will fix it shortly. Link to comment Share on other sites More sharing options...
Folgore101 Posted August 14, 2018 Report Share Posted August 14, 2018 Hi, i'm trying your Wise Disk Cleaner program and i noticed that when cleaning Vivaldi the "Top Sites" file is also removed and this is not good, in this file there are thumbnails of the "Speed Dials" and removing it will lose all thumbnails. I created a rule to exclude this file, but i think it would be better to exclude it by default. Below is a link explaining what individual files do. https://help.vivaldi.com/article/full-reset-of-vivaldi/#backup PS: I really like your program. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 15, 2018 Report Share Posted August 15, 2018 Thanks for your feedback. We will check and improve it. Link to comment Share on other sites More sharing options...
Folgore101 Posted August 18, 2018 Report Share Posted August 18, 2018 Thank you. Link to comment Share on other sites More sharing options...
