wisecleaner_admin 1,335 Report post Posted May 27, 2016 Dear users, We are very excited to announce the release of Wise HotKey beta! Quick Launch and Switch Tool for Windows! Wise Hotkey is a simple and easy- to-use program that can help you improve the efficiency of using computer. It can implement that quick start or quick switch any application, folder or website by using keyboard shortcuts. Click here for direct download Wise HotKey beta However, there is still space for improvement for this beta version, please leave a comment or write down the bugs you found below. We would really appreciate that. Thank you! WiseCleaner Team 3 seanip18, MichaelWeini and IrvingFies reacted to this Share this post Link to post Share on other sites
Mattonius 6 Report post Posted June 4, 2016 Good job, I will try it Share this post Link to post Share on other sites
xilolee 511 Report post Posted June 7, 2016 Hi! I've sent the Italian.ini (as usual), but I can't see the result when using the program. I also request the checkbox Start at windows bootup (or similar). Share this post Link to post Share on other sites
WiseCleaner 1,135 Report post Posted June 8, 2016 (edited) Hey xiolee, Thanks, we will fix it shortly. I found the reason, the language file encoding, your file is UTF-8, but the correct encoding is Unicode. Edited June 8, 2016 by WiseCleaner Share this post Link to post Share on other sites
xilolee 511 Report post Posted June 8, 2016 Ok! It now works and also WSM Italian.ini. Share this post Link to post Share on other sites
clayto 2 Report post Posted June 13, 2016 HotKey will be very useful when a bug I have is corrected. Every new Key I enter vanishes after the computer is closed and restored. This affects both the Alt and the Ctrl Keys. I have tried many times, the way it is intended to be used is surprisingly easy but it is a wasted effort at present. Share this post Link to post Share on other sites
geogeo.gr 50 Report post Posted June 14, 2016 Greek translation to WHK 1.0.1.1 String "Control Panel" showed only in English. WHK_greek.zip Share this post Link to post Share on other sites
wisecleaner_admin 1,335 Report post Posted June 14, 2016 HotKey will be very useful when a bug I have is corrected. Every new Key I enter vanishes after the computer is closed and restored. This affects both the Alt and the Ctrl Keys. I have tried many times, the way it is intended to be used is surprisingly easy but it is a wasted effort at present. Did you use the latest version 1.01.1? Share this post Link to post Share on other sites
wisecleaner_admin 1,335 Report post Posted June 14, 2016 Greek translation to WHK 1.0.1.1 String "Control Panel" showed only in English. Thanks. Share this post Link to post Share on other sites
wisecleaner_admin 1,335 Report post Posted June 30, 2016 Wise Hotkey official version has been released. Please open this page to download and install it. http://www.wisecleaner.com/wise-hotkey.html Thanks. Share this post Link to post Share on other sites
