jaydpiii Posted April 25, 2016 Report Share Posted April 25, 2016 It could be a coincidence, however ... Since I recently installed and ran WiseCare Pro on both my laptop and my desktop, my computers cannot see my networked printer and my printer cannot see them. I have a work laptop without WiseCarePro and it can see the printer and the printer can see it. My printer, desktop, and work laptop are all hard-wired, ethernet, my laptop is wireless. Any suggestions how to fix? I do not ant to have to use a USB to transfer all files to print, then carry the usb across the house to my home office, wake up work laptop, plug in the USB, and then print the requisite file(s). Help? I did run Wise Care Pro to reset windoes with the Wise Care 1st Aid so wondering IF something has to be reinstalled? The printer is still listed in printers and Devices of Windows 7 OS. And document programs can see the installed printer on the computer, but does not see the actual printer on the network, it appears ... :( PatrickAlkat, Donaldmync, Jeffreyvup and 4 others 7 Link to comment Share on other sites More sharing options...
xilolee Posted April 26, 2016 Report Share Posted April 26, 2016 Hi jaydpiii. Have you disabled any windows services? For example, print spooler? Did you try the system tuneup - speedup function? And what did it disable? Link to comment Share on other sites More sharing options...
jaydpiii Posted April 26, 2016 Author Report Share Posted April 26, 2016 I reinstalled the printer on my wired computer desktop. Now it prints once again. I'll check the wireless laptop, might have to do the same. Thx. Link to comment Share on other sites More sharing options...
xilolee Posted April 26, 2016 Report Share Posted April 26, 2016 I may suggest you, the next time you'll use the registry cleaner (in particular, but even other sections), to check each entry to find printer keys and put them in the ignore list. Link to comment Share on other sites More sharing options...
