karl Posted August 26, 2013 Report Share Posted August 26, 2013 files anf folders on the desktop and in the explorer have date and time instead of original names. Operating system:Windows Vista Home Basic (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 3071 MB CPU: Intel® Core2 Duo CPU E8300 @ 2.83GHz Drive Info: C: 464,78 GB D: 0,98 GB F: 465,76 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
april Posted September 5, 2013 Report Share Posted September 5, 2013 Try the following steps please. 1. Open the folder which has this problem. 2. Right-click in empty area and uncheck "View -> Hide File names" option. 3. If this option is not available, press and hold SHIFT key, right-click in empty area and select "View -> Medium Icons" option. NOTE: If above solution doesn't work, enable "Show hidden files and folders" option in Folder Options and then delete "Desktop.ini" file present in the folder which has this invisible name problem. Thanks. Link to comment Share on other sites More sharing options...
