jrfoster 0 Report post Posted January 3, 2016 Every 5 minutes I get a pop up in the lower left hand corner the clear the memory and then it lists the memory, usually only 159mbs or so. It is very annoying. How do I stop it? Share this post Link to post Share on other sites
xilolee 511 Report post Posted January 3, 2016 Hi jrfoster. Custom, settings, tray, untick Display floating window automatically when running wise care 365. Share this post Link to post Share on other sites
jrfoster 0 Report post Posted January 3, 2016 Thank you. I will give that a try! Share this post Link to post Share on other sites
jrfoster 0 Report post Posted January 4, 2016 That solution of unticking the box did not work! It is still appearing and driving me crazy. Anyone else seeing the "clear the memory" box that pops up? There has to be a setting that fixes it. Share this post Link to post Share on other sites
xilolee 511 Report post Posted January 4, 2016 Untick also the setting under it: Auto-optimization Share this post Link to post Share on other sites
jrfoster 0 Report post Posted January 4, 2016 I will give that a hot also. Something has to work! Share this post Link to post Share on other sites
