11Al Posted December 23, 2015 Report Share Posted December 23, 2015 I have this problem with RG Portable version, the RG icon appears in system tray and then disappears after a few seconds. No message. After this I check manually, it deleted nothing. It doesn't work at all. Then I checked in the Windows TaskScheduler and I have seen that the task is set up for Windows 2000 and XP, maybe the parameters of the task would be updated. Anyway in the scheduled task, it would be added the option of repeating task if the PC was turn off, hibernate or sleep at the scheduled moment. Thanks in advance. Windows 8.1 Pro x86. Happy holiday AlexissEn, cloncuche, DonaldSl and 11 others 14 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 24, 2015 Report Share Posted December 24, 2015 Hey, Maybe there is nothing to be cleaned. You can do a test, scan system manually (only scan, not clean). then create a task and wait. When the task is running, you can check whether the cleaner is working. The parameter - Windows 2000 and XP, it is fine, no need to update. About repeat task, we will consider it, thanks. Link to comment Share on other sites More sharing options...
11Al Posted December 27, 2015 Author Report Share Posted December 27, 2015 But since I had already written, I have made this manual test, there were out some problems to be removed, but the automatic cleaning does not remove anything. Link to comment Share on other sites More sharing options...
Newsqueuene Posted May 30, 2017 Report Share Posted May 30, 2017 Half the time I turn off the auto start function and mainly use it if I know Im going to be at a light for more than 15 seconds. Im I the only weirdo that does that? Link to comment Share on other sites More sharing options...
