waynezo Posted September 10, 2015 Report Share Posted September 10, 2015 I was able to upgrade install Win 10 and the only error message was "this is taking a little longer" I ran SFC and it didn't find any bad system file. System was sluggish and windows explorer would crash. I called XFX tech support and they said there are no drivers for win 10 for the 4770. I would have to buy a newer card.Is this correct? I don't want to buy new video cards just to get win 10?Any advice is appreciated Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 11, 2015 Report Share Posted September 11, 2015 I'm not sure the video card driver cause the issue. Does the motherboard built in a graphic chipset? If yes, you can plug out the XFX video card. Then update to Win 10, when the update is complete, plug in the video card. Windows will install the driver automatically. My video card is AMD Radeon HD 4250, my Windows 10 is working well, update from Windows 8.1 Link to comment Share on other sites More sharing options...
