jkcharlie
Wise Care 365 3.8.3 PRO error!
Hi jkcharlie.
I think you should provide at least your configuration, in order to get (effective) help from developers/admins.
For example, you could answer these questions:
- Laptop or Desktop?
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
- System Manufacturer?
- Exact model number (if laptop, check label on bottom)?
- OS (Windows 10, 8.1, 8, 7, Vista, xp, other)?
- OS version (standard, home, home basic, home premium, professional, ultimate, enterprise, other)?
- x86 (32bit) or x64 (64bit)?
- What was original installed OS in your PC?
- CPU?
- Video Card?
- MotherBoard (if NOT a laptop)?
- Power Supply - brand & wattage (if laptop, skip this one)
You can find them using wise care 365 --> system monitor --> hardware overview and/or using Microsoft msinfo32 (click windows start, then all programs, then accessories, click command prompt, type msinfo32 in the command prompt black window and press enter on your keyboard).
Hey jkcharlie,
Thanks!
Maybe there was something wrong with the registry, but I'm not sure.
Please download this portable wise registry cleaner, don't need to install it, just extract the zip file, then click WiseRegCleaner.exe
It will show us the real error message. Please upload it.
Thanks.
Wise Registry Cleaner Portable.zip
thanks. I don't know how to find the error message, I clicked the WiseRegCleaner.exe, and the WiseRegCleaner windows shows up, but I didn't see any error message. and I was trying to upload the WiseRegCleaner.exe , but it says I don't have permission to upload this kind of file.
Thanks very much!
The error message - Insufficient system resources exist to complete the requested service.
You can try something:
1, Please exit (disable) the antivirus software, then try to defrag registry again.
2, A possible reason is the Nvidia graphic card  driver. Please update it to the latest one. you can download it from its official website.  Then try to defrag registry again.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
