biggusdickus Posted September 3, 2015 Report Share Posted September 3, 2015 Every time I run a checkup/fix on Wise Care 365, with StartIsBack++ installed, my Windows 10 metro (or whatever you call it) apps stop working. I always get the following error when I try to run one of them: If I uninstall or reinstall StartIsBack++ everything works great again. A fix for this issue would be much appreciated. TimothyFut, Mablenige and JosephGefs 3 Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 11, 2015 Report Share Posted September 11, 2015 Thanks for your feedback. You can add a registry key into the Exclusion List. 1, Open wise care 365 -> Custom -> Settings -> Exclusion tab 2, Find Exclusion Registry Key, and lick Add Key 3, enter HKEY_CLASSES_ROOT\StartIsBack.ImmersiveApplication\Shell\Open\Command 4, click OK to save settings. Or, you can open Registry Cleaner, and Scan, then find File Types, find this key, right click it and click Ignore this item. Link to comment Share on other sites More sharing options...
biggusdickus Posted September 14, 2015 Author Report Share Posted September 14, 2015 Thank you. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 16, 2015 Report Share Posted September 16, 2015 You're welcome! Link to comment Share on other sites More sharing options...
