Nesivos Posted August 18, 2015 Report Share Posted August 18, 2015 I always download and save the latest installer file. Usually I update from the installer file though WC 365 has an update feature. Suggested improvrments to WC 365 installer file 1. Give users the option to not create a desktop icon. Ususally if you are installing over a previous version of WC 365 Pro you most likely do not need a new desktop icon druing an installtion of WC 365. So do what a lot of other apps do and give users the option to not create a another desktop icon. 2. When you download the installer file from MajorGeeks and select download from author's site the download comes from an insecure (by definition) HTTP website. I know because I have an app that blocks all http websites, unless the feature is turned off, and the WC 365 download is blocked when I have the blocking software set to block HTTP websites. Change the installer file to download from a secure HTTPS website. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 19, 2015 Report Share Posted August 19, 2015 Thank you fro your suggestions. 1. Give users the option to not create a desktop icon. Ususally if you are installing over a previous version of WC 365 Pro you most likely do not need a new desktop icon druing an installtion of WC 365. So do what a lot of other apps do and give users the option to not create a another desktop icon. The earliest version (v1 and v2) contains this options, user need to click 7 times Next button to complete the installation. we hope the installation can be more simply, remove some steps, now, user only need to click 4 times to complete the installation. 2. When you download the installer file from MajorGeeks and select download from author's site the download comes from an insecure (by definition) HTTP website. I know because I have an app that blocks all http websites, unless the feature is turned off, and the WC 365 download is blocked when I have the blocking software set to block HTTP websites. Change the installer file to download from a secure HTTPS website. We will consider it. Link to comment Share on other sites More sharing options...
