MichaelB Posted August 6, 2015 Report Share Posted August 6, 2015 After downloading Windows 10 (from 8.1) I encountered most of my desktop icons to be a blank white page (no original color icon). Need to get those back, please. Operating system:Windows 10 Home (64 bit) System root: C:WINDOWS Available physical memory: 3978 MB CPU: Intel® Celeron® CPU N2830 @ 2.16GHz Drive Info: C: 456.94 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 7, 2015 Report Share Posted August 7, 2015 When you click the icon, can you open the program properly? Did you use wise pc 1staid to fix this issue? (the 1st icon, Desktop Icon Error), You need to restart PC. If it doesn't work, delete one issue icon, open the program's folder, find the executable program(the exe file), right click and select Send to -> Desktop (create shortcut) Link to comment Share on other sites More sharing options...
