redace
Wise Program Uninstaller freeze
Hello !
I have used Wise Program Uninstaller a lot when i need uninstall something, but now i have a problem ...
When I start WPU it stay indefinitely on "collecting informations about programs on your computer"...
I hope you can do something for me because i really need this program !
Thanks to you !
PS: If there is Logs to send, say to me where i can find them !
Yes, yes, unfortunately, this is true. Wise Program Uninstaller 1.73.92 not work!!! :-(
After starting the program:
"Collecting installed program information..."
Then just hourglass...
Then just wait, wait, wait ... and nothing. :-(
My system: Windows XP SP3
My Firewall: Comodo Internet Security Pro 8
Xilolee Hi!
Thank you for your reply!
I tried. I did the following steps:
1. Wise Care 365 -> System Tuneup -> Startup Manager
2. Operation: "ON" only the Wise Care 365
3. Windows restart
4. Wise Care 365 -> PC Checkup -> Utilities -> Program Uninstaller
Result: not working, freezes :-(
I ran the DirectX dxdiag.
Details of the results:
System Information
Time of this report: 9/12/2015, 12:19:18
       Machine name: xxxxxxxxx
   Operating System: Windows XP Professional (5.1, Build 2600) ServicePack 3 (2600.xpsp_sp3_qfe.130704-0421)
           Language: Hungarian (Regional Setting: Hungarian)
System Manufacturer: Gigabyte Technology Co., Ltd.
       System Model: GA-MA770-UD3
               BIOS: Award Modular BIOS v6.00PG
          Processor: AMD Athlon 64 X2 Dual Core Processor 4400+,  MMX,  3DNow (2 CPUs), ~2.3GHz
             Memory: 2046MB RAM
          Page File: 651MB used, 4309MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
        Card name: ATI Radeon HD 3800 Series
     Manufacturer: ATI Technologies Inc.
        Chip type: ATI Radeon Graphics Processor (0x9501)
         DAC type: Internal DAC(400MHz)
       Device Key: Enum\PCI\VEN_1002&DEV_9501&SUBSYS_E620174B&REV_00
   Display Memory: 512.0 MB
     Current Mode: 1024 x 768 (32 bit) (85Hz)
          Monitor: Samsung SAMTRON 95P Plus(T)/95P
  Monitor Max Res: 1600,1200
      Driver Name: ati2dvag.dll
   Driver Version: 6.14.0010.7060 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Sound Devices
            Description: Realtek HD Audio output
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458E601&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RtkHDAud.sys
         Driver Version: 5.10.0000.5780 (English)
            WHQL Logo'd: Yes
          Date and Size: 1/20/2009 12:53:06, 5027840 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 9.2 GB
Total Space: 51.2 GB
File System: NTFS
      Model: SAMSUNG HD501LJ
      Drive: D:
 Free Space: 11.1 GB
Total Space: 220.0 GB
File System: NTFS
      Drive: E:
 Free Space: 17.4 GB
Total Space: 205.7 GB
File System: NTFS
      Drive: F:
      Model: TSSTcorp CDDVDW SH-224DB
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (Hungarian), 4/13/2008 19:40:46, 62976 bytes
System Devices
     Name: SUNIX 1-Port Parallel Card
Device ID: PCI\VEN_1409&DEV_7268&SUBSYS_01031409&REV_01\4&CC5B14E&0&38A4
   Driver: C:\WINDOWS\system32\DRIVERS\snxpcard.sys, 6.04.0000.0000 (English), 12/20/2007 04:26:00, 17536 bytes
   Driver: C:\WINDOWS\system32\snxprops.dll, 6.04.0000.0000 (English), 12/20/2007 04:26:00, 27136 bytes
     Name: ALP8CEBE IDE Controller
Device ID: PCI\VEN_1103&DEV_0005&SUBSYS_7F706A3F&REV_01\4&5D18F2DF&0
   Driver: n/a
     Name: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC
Hello Guys !
Sorry to make my return a lot of time after the beginning of this topic but nothing has changed ...
My computer is now on W10 (and it's great) but Wise Program Uninstaller still turn in the void ...
I can't find any log file in all folders whit WPU Tag and that's not cool ...
I don't know why WPU is not working ! My computer is from begining of 2015 so he's not old ! Now he's on W10 ...
So ... someone can do an update to implement logs ? Or give any information about he's localization if they are actually existing ???
Thank you
Unfortunately, the situation is as follows.
The WPU older versions excellent work, but the newer ones are not. Why? Where is the error? The culprit is the Wise Program Uninstaller 1.69.89 and the higher versions. Let's see the update history! (http://www.wisecleaner.com/blog_sort_11.html) A black day in May. 18, 2015 ---> Wise Program Uninstaller 1.69.89
Changes:
 Forced Uninstall function improved.
 Feature Optimized cleanup of residual items.
 Improved localization and language support.
 Minor bug fixes and GUI Improvements.
Just guessing, but I think of them the culprit:
"Improved localization and language support."
I would like to ask for the correction of the program, to work on not only old versions! Excuse for my poor English! Thank you!
Dear WiseCleaner Administrator!
Many thanks for your efforts!
Unfortunately, there is no improvement. The new Wise Program Uninstaller v1.74a (v1.7.4.93) is not working.
It stops at the same place as the old v1.69.89, v1.71.90, v1.72.91, v1.73.92 versions.
Then wpulog.txt looking for the file, but not there. I went through the entire C: drive, but in vain, nowhere.
When a program crashes, I can not close.
I can only shoot down roughly: Ctr-Alt-Del -> Windows Task Manager -> Task completion
Hello !
Thanks to you Wise for your consideration but there is no change ...
The program still turn in the void indefinitely and i'm forced to use the task manager to close it ...
If you need any other information, you know how to contact us ...
Good luck
Same than Tip-Top ...
My boot is cleaned and only System, Avast, Nvidia, and Logitech (my mouse). (Spybot too)
But with the old version, I was starting this programs on boot and WPU was working well !
@Tip-Top
Thanks for your feedback.
Please search the file again, open %appdata%\wpulog.txt, or %appdata%\wise uninstall\wpulog.txt
Another requirement, please export two registry items and send to us. Thanks!
1, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
2, HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall
@wisecleaner_admin
• The wpulog.txt not there, I'm sorry.
• Export two registry items:
• 1, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
This I found. ---> 1-Uninstall.reg
• 2, HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall
Here they are in trouble:
I found only HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft
---> 2-Wow6432Node-Microsoft.reg
I not found HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall
I would like to propose a simple but purposeful debugging:
• Wise Program Uninstaller 1.68.87 [2015.03.22] - It was the last working version.
• Wise Program Uninstaller 1.69.89 [2015.05.18] - It was the first non-working version.
In the 1.69.89 version was change and development "A", "B", "C", "D", "E".
Please make for me separately:
• Wise Program Uninstaller 1.69.89 tempwork-A.exe
• Wise Program Uninstaller 1.69.89 tempwork-B.exe
• Wise Program Uninstaller 1.69.89 tempwork-C.exe
• Wise Program Uninstaller 1.69.89 tempwork-D.exe
• Wise Program Uninstaller 1.69.89 tempwork-E.exe
Then I install separately, and I test separately elements of A, B, C, D, E versions, and I indicates which one works and which one is not working. So you can quickly narrow the circle.
Yes !
WPU is working !
The first time , WPU has crashed with an error but the second time he started .
Now i can uninstall programs easily !
Thanks for your support ! (you can release this version ;-)   )
Small problem, maybe it should not for word, but I speak.
I upgraded to version 1.75.94 of the Wise Program Uninstaller, but still I get a message after program restart:
"A newer version of Wise Program Uninstaller is found. Do you want update it now?"
