Sign in to follow this
Vict
Disk Eraser
What i mean is on the disk eraser at the bottom where it says security and when you click on the arrow you bring up a list at the bottom. It says Guttmann 35 passes does that mean that the driver is  fully erased when used.
Yes, you are toally right.
The higher you passes, the more the drive is ersased when done.
GUTTMANN 35 PASSES is the highest standard, when you choose it, it will erase your drive thoroughly, while it will take a little longer time.
Thank you very much for your support.
Contact us if you have any other issues. :D
